X xroxis01 Member Jun 26, 2009 #1 does my video card update automatically......??????? and when it updates is it also in windows update??????
Gareth Active Member Jun 26, 2009 #2 No, your video card will not have auto update, the ones on Windows update are generally out of date. What video card do you have?
J Jamin43 banned Jul 2, 2009 #5 xroxis01 said: geforce 9800 gt Click to expand... Video card updates will likely be found at your card's manufacturer site. i.e. XFX, EVGA, sites, etc.
Okedokey Well-Known Member Jul 3, 2009 #6 Look here: http://www.nvidia.com/Download/Scan.aspx?lang=en-us
ScOuT VIP Member Jul 3, 2009 #7 You will need to manually update video drivers. Go here and type in your information. It will save the file. Run the file and it will install the newest driver released. http://www.nvidia.com/Download/index.aspx?lang=en-us
Okedokey Well-Known Member Jul 3, 2009 #8 ScOuT said: You will need to manually update video drivers. Go here and type in your information. It will save the file. Run the file and it will install the newest driver released. http://www.nvidia.com/Download/index.aspx?lang=en-us Click to expand... bollocks bigfellla said: Look here: http://www.nvidia.com/Download/Scan.aspx?lang=en-us Click to expand... The thread above will automatically detect if his graphics card needs an update. I would also suggest updating DirectX here: http://www.microsoft.com/downloads/...38-DB71-4C1B-BC6A-9B6652CD92A3&displaylang=en
