Need help with gaming desktop parts
pauldave
Hey, I want to build my desktop for the first time. I am looking for a gaming rig that cost around $1200.00 usd. Can anyone help me pick parts off of newegg that are compatable. I think with the help of this forum and some other sites I will be able to put it together. I am just unsure on compatable parts. Thank you for your time in advance!
awesome, thanks. I am thinking about getting a 2nd vid card the same you have up there. is there room for that also what size monitor would be good for that set-up?
If you got a second video card...I would recommend a 22" or 24" monitor.
Personally I would not buy 2 lower end cards...I would buy one high end card. Two of those cards will cost you about $250. Here you can get a GTX 275 for about $200 after mail in rebate. Then maybe in a couple months you save a little more money and then SLI the GTX 275:D
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130475
I third the 4890. Much better card than the 250 for sure, which is pretty much the only chink in the armour to Bodaggit's build, you won't be disappointed with that set up.
