First Time Builder Looking For Review of Parts
TpLoS
I think you are looking at American Dollar prices and not Canadian. All the parts look compatible but I would suggest you change some components.
This power supply is great quality and less expensive:
OCZ StealthXStream OCZ700SXS 700 Watt Power Supply - $90
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817341019
This case is also less expensive and decent quality:
Antec Three Hundred Black Steel ATX Mid Tower Computer Case - $60
http://www.newegg.ca/Product/Product.aspx?Item=N82E16811129042
Nvidia video cards work better with Intel processors I hear. Take a look at this:
XFX GX260XADJF GeForce GTX 260 Video Card - $206
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814150361&Tpk=XFX GX260XADJF
You are also missing an operating system:
Microsoft Windows Vista Home Premium SP1 64-bit - $140
http://www.newegg.ca/Product/Product.aspx?Item=N82E16832116488CVF
Everything looks great except 1 thing. Unless you are going to raid those hdd's I suggest you get 1tb hdd with 32mb cache instead of 2 320gb with 8 cache. It will cost you 100 bucks just like 2 of those you chose.
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136284
Stick with the psu you chose because down the road when you wanna get a second 4870 it has 4 pci-e connectors and it will provide enough amps for crossfire.
For operating system just get windows 7 rc and then buy it once its available.
You should forget about get a LGA 775 motherboard they are being outdated quickly and no more CPUs will be made for them. Try looking at some AMD CPUs and motherboards they will be cheaper then Intel if you do go with AMD it would probably be best for you to get a AM3 motherboard and CPU.
Here you go http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.211665 both CPU and Mobo for only $275 that save you $75. Get this 4870 instead http://www.newegg.com/Product/Product.aspx?Item=N82E16814150394 it is $5 cheaper plus free shipping so that is about $85 you just saved. I've picked out another case for you also http://www.newegg.com/Product/Product.aspx?Item=N82E16811156062 it's $30cheaper and just as good. So that a total of $115 you just saved.
Prob. because once you get the quad-core 2.83ghz you won't need another CPU
for the rest of your life - unless they come out with those quantum processors
they have been talking about.
All current motherboards will be absolete once DDR3 takes over - scheduled for 2010?
The motherboard you suggested has 55% 5-star rating, the gigabyte has 73% 5-star
rating.
wow thanks for all the great advice
i dont understand the RAID thing, or why i should only buy 1 HDD:confused:
i want to have like a C and D drive and not just a C drive so thats why i got the 2 HDD, unless thats wrong?
I have two hard drives in my present system and I love it. I would suggest two hard drives. You can duplicate your valued data effortlessly with two hard drives. And if one of your hard drives fails you can have a duplicate of your valued information.
