Cable Sleeving
If you just want the best sleeving, the Murdermods is considered top quality. But if he just wants to cheaply sleeve his cables to get them a bit better looking then it is way out of his price range.
I don't have any experience with the Thermaltake stuff. A while ago I got some really cheap stuff at xoxide, and you definitely get what you pay for. Cheap plastic sleeving was what I got.
If you've got the money to drop and the patience to do it right, then go murdermods. But sleeving takes a while to do perfect, so take your time, especially if you drop the money for MM.
Edit: And I have heard a lot of good things about the sunbeam kit. But it is only really useful if you are going to do more than one psu, or if you want the process to be quickened some.
hey, go to walmart, in the automotive department they have some wire tubing in three different colors, It works really good to hide cables.
I agree it might look good. on the otherhand if ya had to get into that mess ya might not like it. some small wire tys looks good. its neat and can be cut if troubleshooting is needed. sleeve would be a nightmare.
