wantedelite
Computer Build Under $1000
I need a gaming computer build for under 1000 Canadian using ncix! Nothing else other than ncix!
Use this and select the best build for under 1000 using either vista 64bit or xp 64. Which ever one you guys suggest!
http://pc.ncix.com/pcbuilder/index.php?action=config&id=3046611&platformid=1000
It must ahve 4gb of ram and ddr2 I dont want ddr3 since it costs way to much and what ever is the best for that price and if the video card is 1gb that could be great and what ever you guys think is the best for 1000 Canadian nothing more than 1000! just a bit over is ok but nothing like $1100!
Thanks in advance!
Thanks in advance!
