Hey guys,
Okay i have a new XFX 4890 1GB....i love this card,its a beast.
But one problem....its fan,its started making a clicking noise,just like the sound as if theres a wire been hit by the fan....that sort of sound,but theres no cables near it.
If i manualy turn the fan up in Catylst control panel then the noise goes.
Also ive noticed that,when im in game menus or loading games it maks a slight squeeling sound,now i heard this can be caused my some sort of electric coils on the card and that hot glue is the fix? lol
I emailed XFX about this and this was their reply...
he replied...
this card is loud enough of low speeds,i would not want to run it higher that 50%
Do you guys think i should return this card? RMA?
the card runs quite cool though 42c idle....not tested load temps yet but i bet she gets hot.
checked...no damage from what i can see,and nope no cables in the way.Hi Shane, thanks for your message. Check the fan for any physical damage and make sure there is nothing obstructing it. Is the noise definitely coming from the fan, could it be coming from somewhere else? Thanks, Shaun.
he replied...
Hi Shane, thanks for the extra information. If increasing the fan speed resolves the issue, you may just want to keep the fan speed a little higher than usual. It shouldnt make any difference or effect the lifetime of the card. However, if you are concerned, you can return the card to your reseller, as they hold the warranty for the product. Let us know if you have anymore questions. Kind regards, Shaun.
