Larger Power Supply or more RAM ??
Crucial is an ok brand for RAM. Just look out for the FSB ratings. one might be 533mhz and another might be 800mhz. make sure your motherboard supports it too.
Thermaltake is no longer a reliable brand for power supplies.
Absolutely not, thermaltakes power supplies are all at least somewhat decent, its not going to be a high end unit unless you get a toughpower, but i would trust it over say, a rosewill.
and :gun: Rosewill lol:mad::(
:mad: Rosewill sucks, they are built by the cheapest bidder. You can have one made by one company one week, and an entirely different company the next.. The only low end psu i would even consider would be a compucase/hec.
Riiighhht Bomber.
A Factory In China, With Lots Of Chinese People Working There, And In The Same Factory Corsair Is Being Assembled By The Same Chinese People. lolz
:good:
Solytech makes the majority of rosewill power supplies, a company with not the greatest reputation on power supplies. They are known under many different names such as allied, Deer, Apex, list goes on. ATNG Also makes a few of the rosewill power supplies, which also arent that good. Looking at Xclio, their power supplies are made by CWT(channelwell, also makes the corsair power supplies and a few others) and Enhance(Makes some of the Tagan, Antec, silverstone, and a few others). Also for example corsair, their units are also made by CWT and a few are made by seasonic. PCpower&Cooling power supplies are made by seasonic for the majority.
Don Worry Rosewill Will be Big Soon.
Rosewill= mostly made be ATNG and Solytech, some are Wintech and Youngyear. But that could change by tomorrow or next week or next month. You can find out by the UL number on whatever model your looking at.
? Rosewill is newegg house brand, cheap components. Just like bestbuy has "dynex" and "rocketfish"
My Friend From School has A 500Watt Rocketfish Modular Power Supply, Had It For Over A Year Now, No problems at all. I mean I would not buy it for a high price as rocketfish used to sell for, but other than that I see no problems with them. What If Antec Was Like Bestbuy's House Brand? Would you still bitch that its cheap and unreliable because it is a house brand?
There is no if, antec has been around for a long time and uses quality components. The quality of components used in the power supply is what matters most, and FSP, Enhance, CWT, and Seasonic are known to make good power supplies. Its not they they are house brands, its the fact they use cheap and unreliable components.
as long as it works well, then its all good.
