Is 18 Amps enough for 9600gt?
It depends what kinda power supply, if its a cheap chinese power supply, it probably doesnt even put out 18A. If its a seasonic, antec, or another quality manufacturer, it might be alright, but i doubt it.
When in doubt
http://www.computerforum.com/90110-power-recommendations-video-card.html
My uncle couldn't run a 8500GT on a 18amp PSU which is 21amps for the card with a similar set up as you...9600GT.................................400W .........................26A
At this point even if its a Corsair 18a PSU your not meeting the power requiments at 18a.
The only card I see you might be able to get away with is 8500GT.......300W ......18A or the 8600GTS..........350W ..........18A
I'm able to run 8500GT on crap 250W PSU from compaq :D
Well yeah you can "run" it...but your not getting half the power the GPU can dish out. Plus the extra side bonus of overloading the PSU for a possible PSU failure that kills your system.
Just telling you what it says...you can decide what you wanna do.
