erebusting
I currently have my 920 OC'd to 3.4 ghz and My ram at about 1600mhz 7 7 7 24 1t timings ...
Ok so Idle I get about 33-34 degrees C
running prime 95 I am currently getting a max temp of about 65 degrees C and under...
I have a Scythe Mugen 2 HS, AC MX2 compound..one of these :http://www.newegg.com/Product/Product.aspx?Item=N82E16835103022
on one side
and on the other I have this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103061
...any ideas? are those bad temps?.... I believe my dram voltage is set to 1.64 right now maybe that is an issue? (I want to be stable)..
on one side
