I'm looking for a new case
Fatback
I can't stand looking at this case any more it's driving me crazy I will never buy cheap again.
What I'm looking for
Black Interior(would be nice but not necessary)
Really good cooling
Good cable management
2 or more external 5.25 bays
1 or more external 3.5 bay
4 or more HDD bays
mid or full tower
Good cable management(I know I already said it)
$100 price range
I found this one but I didn't really look hard figured I let y'all do the work lol
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146055 I like the inside but I'm not crazy about the front.
I personally like this case. It's a coolermaster and is $80. They have another identical version that is for Nvidia that also comes with green lighting instead of blue that is $100.
That is a nice case and it can hold 7 120mm fans which is very nice. I will have to consider it of course I will have to switch the fans out for red ones but that's no biggie. I'm wonder how the cable management would be with the power supply being at the bottom I don't see much room behind the back panel to had any cables.
i really like these fans, newegg has it to for $1 less but i dont thnk they have red.
I have the 590, which is the same thing, just tool-less. I haven't really tried that hard, but what I did try cable management was really easy. I have 3 SATA drives and my TX850 PSU which has a TON of power cables. I have no airflow issues. I recommend either the 690 or Centurion 590.
