I am kind of new to this. Is it difficult to change the settings of the i7 920 so that it can utilize DDR3 1600 instead of DDR3 1066?
You just enter the correct timings in the BIOS, save and Exit.
Where do you get the correct timing from?
See how they all list a "Timing". That's what you change in the BIOS.
http://www.newegg.com/Product/Produ...50001666 1052429371&name=Corsair (XMS Series)
the following changes will reduce the lifetime of CPU, DRAM, or CHIPSET. Do you want to continue and save settings
