New case?
MouSe
I currently have a Cooler Master Centurion 590 Mid ATX case. It's getting the job done with no problems. I just want something a little more flashy, with a sidewindow so I can see all my goodies. Lookin for some help because I'm kind of picky and would like some recomendations, even if that rec is to just keep my curent case.
So what the new case has to have:
Black or Silver finish
Bottom mount PSU
Side fan vent kind of near the middle, as to not hit my MASSIVE CPU cooler.
Top fans.
This is the only one I've seen so far that really nails what I want;http://www.newegg.com/Product/Product.aspx?Item=N82E16811146047
Alright, tell me what you think I should buy, if anything.
I was gonna say you should buy the Tempest, but the cheap metal thing discourages me. I looked at the product tours, and the 900 seems the better choice regardless of price.
They are about the same price I just noticed. If I would have seen that the first time I wouldn't have even put that other one up. :D My buddy has the 1200, which is the same thing just a full tower.
I don't like cases with rear mounting hard drive racks. Pain in the arse to swap
drives if you have a large GPU.
Side mount FTW. :good:
On that AZZA the Power button and ports are mounted on the top. You pop the front off and the harddrive cages slid out of the front.
I agree for the $100 budget id get this or a Antec 900/1200 case. Both are great for airflow and the 900/1200 are sturdy and don't move or bend like a lot of cases. lots of metal = secure and no vibration issues.
If your handy with a dremel you can do beautiful cable management with the Antec cases as well (google some are truly fantastic)
Even without such talent you can do a semi-professional set up....or you can be like me and make it look ugly but clean the air passages ^-^
