did i made a mistake on choosing cpu?
which is better?
  • Total voters
    14
UpskirtHayley
did i made a mistake on choosing cpu back in 2004?
options are dual core pentiumD 2.8ghz and pentium4 3.0ghz (630)
i swap the pentium D for the 630 with no extra charge. price stays the same. did i made a mistake?
fixed:
forgot to say the pentium D runs at 2.8ghz
It was 2004, doesnt matter now if you made a mistake. You got what you got. There are things I got in the past, that I probably should have got something different. You just go damn, learn and move on.
It's 2009, a little late to worry about what processor was the right one, strangle hold is right:
+ Dual core will be better than the single core fo sure.
Upskirt has his years off alittle anyway. The Pentium D was released till sometime later in 2005
oh then it must be that time then. been so long cant remember perfectly.
damm was hoping i made the right choice. back there i never heard of pentiumD and not familiar with it. i thought its gonn be some cheap line such as sempron so i scrap it and get a familiar p4 3.0ghz HT 630 instead with no extra charge. later on found out the pentiumD was a dual core then starting to concern and regret.
