need help for emergence
darkdragonz
i just installed quickfreedom(for jailbreak of i touch)
after i installed it and restarted my laptop
then is shows blue screen after starting the window vista
what can i do?
i had tried to go in safe mode and trying to uninstall the program but the uninstaller is in my USB memery stick and i can't use my USBs in safe mode
there are a lot of important data in my lap top and i do not have them backed up
if i cannot get those data back
i think i will need to kill myself for it:(
what can i do?
malware is my guess, dont be worried, try this, download and install then run a quich scan and remove threats
Go into safe mode and uninstall the stuff you installed.
If that does not work then do a system restore in safe made.
here is a picture i took with my phone for the blue scrren
a system restore would reformat the disk, so ya all gone...how long do you have before it reboots?
which mean all my homework,assiments,data and all my photos will be f**King gone?!
d**n, i hate that
all my photos of my childhood are in my f**king laptop and those are the f**king only copy!!!!
f**k that!!!:angry:
