maybe a bit excessive for a 2160
Would like some peoples views/comments
Only time i tell people that is when they are building a new rig and looking at the current 775 quads or higher priced dual coresHe's all set to drop in a Quad. So much for not being able to upgrade a 775.
Looks sick dude. Very clean. :good:
i can tell by the cable running from the motherbord you have a very clean build, i have the white tubing on my rig too
looks very nice!
whats the cpu your using and the temps with cooling?
Looks nice, maybe a bit excessive for a 2160, but nice nonetheless
Hey, have been away for a while, but im back.
Just re did my loop, cleaned everything and added a new reservoir and white tubes.
Thanks
 Nice though.
 Nice though.Hehe, i was gonna ask that too but noticed he had specs in sig54oC is my max temp with my i7 920 co stepping @ standard!
not a bad temp for %100 overclock
what size radiator are you using and what pump?
Funky is running a watercooled setupThe stock i7 cooler isn't very efficient.
)Hehe, maybe this?How would I know that?...Outdated sig...
He said "54oC is my max temp with my i7 920 co stepping @ standard!" so
I thought he meant on the stock cooler at stock clocks.
(I also assumed he meant 54c, and not 540c)
 (i think)
(i think)Looks rather clean and neat on this end....though the crop photo makes me think your hiding your cables off to the side ^-^
