Unattended software
atomichybrid
Hi guys,
I was googling on some software to make an unattended windows installation, since i do a lot of formatting for friends and family. I was just wondering is there a software that can make an unattended windows installation and also make unattended installations of other programs such as MS Office 07, Nero, Winrar and etc. I have used nlite and Windows Unattended CD Creator (WUCC), but they dont do the software part too well since I have to click 'next' and 'finish' all the time. If there is a software much will be appreciated.
Cheers
If your going to the trouble to format and wipe is what i do install the operating system, get all the critical and security updates. get the internet working, email account, install all the programs then backup one time with Acronis true image. then you can at least get it back to this state.
Hi guys,
Cheers
Um, if you do it properly all you need to do is select the partition to put it on then it's completely automated, but you need to insert your license key beforehand so you'd need to make a disc per system you normally reload
I've heard about this program from a friend but this seems to take an image of your computer's current state, I need a software that does a fresh unattended install because of the drivers might conflict with other computers if I'm using Acronis.
What do you mean by select partition?
There is a software called almeza multiset, which might interest u.
I havent used it by as far from reading from the info given in the website, u have to record the installation of a setup by virtually installing the software inside the Alzema multiset. Then it automatically playbacks (repeat same steps) when u install it on a pc.
This could be the program, this will now save me some time, thanks for the post.
