Hi, I recently paid a 16gb usb key on eBay and it seems to have problems. for example : I cannot save some photos, I made a PC folder and some files may and some files may not be saved in another folder in this folder. it disappear next time i plug my key. i have to save it out of the folder to make it save. I don't understand because some files may be saved in a different folder, and other files just disappear.
I cannot format to NTFS even by following methods, (http://www.ntfs.com/quest22.htm) it tells me something like Windows was unable to format bla bla..
And before i format into fat32, word files were messed up, and some files were not saving.
maybe the problem is that the eBay key might be really cheap? ( I paid 16$ for 16Gb Key...)
PS : Also, may the key be less than 16Gb?? (since it was only 16 bucks) I fear that it may only be fake 16gbs
Thanks you!
Thanks you!
