First time Gaming build on a budget
Branny
Hello this yeah instead of buying aa computer i decided i was gonna build my own gaming build.
im looksing for a build that can play world of warcraft call of dut 4 and 5 and farcy 2 on high settings for under600 dollars after s@h i have a current build so far that i made up but plz tell me if theres anything i should do to improve it or to lower the price without lossing proformance
http://www.newegg.com/Product/Produc...82E16827136168
http://www.newegg.com/Product/Product.aspx?Item=N82E16811208009
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131381
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161244
http://www.newegg.com/Product/Product.aspx?Item=N82E16817104053
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145184
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103678
the guys at pcmech helpeed me with this one i just wanted to get a second opinion
someone told me that power supply has been getting sent back alot
but i might just take my chances with it to save some cash
The OCZ Modxstream is an excellent power supply, and that FSP is also a decent power supply but you can do better for the price(FSP Makes the ocz GameXstream line).
Another good psu incase your interested, same specs as that fsp pretty much for better price:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817189014
4870 for basically same price as that 4850:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131140
Memory, better timings, few bucks more before rebates, but insane rebate on it:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220293
Better cpu, cheaper:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103687
Might wanna think about this case:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119203
ok i liked alot of that new stuff except the video card.. the reviews kinda scared me a bit
but the new cpu saved me about 10 bucks so im about 15 under my spending limit (i like to be right on it hahaha) so i was thinking i could spend another ten bucks on a better video card.. any suggestions?
