I need a gaming computer $700 budget!
homer 2881
I need a good gaming computer for around the price of $700, it's ok if it goes over a little. But that's my tower only, not including everything else. But I don't know anything about computers, so I don't even know which one would be the best for me.
I'll be using it for games such as WoW, Crysis, and all the new games coming out. And Also want it to run the internet fast.
I've found nice computers at Cyberpowerpc.com, but there's so many choices!
Can anyone suggest a good computer that would fit my needs. The only problem is I don't understand computers and all the specs. =/
i suggest that you build it yourself, using parts from newegg. putting it together is actually really easy, and if you run into trouble there are a ton of guides online. in the end you'll get a much better PC for a lot less money.
That's what I keep hearing, but I know absolutely nothing about computers. I don't even know what pieces I need to make it run.
we can help you with that :)
i highly suggest you do this, trust me. we can recommend all the parts for you and everything.
^ True.
You should start with a computer case, doesn't have to be anything fancy or expensive but should have good airflow.
Then comes the motherboard, probably the hardest thing you'll have to choose.
The other guys can help you with that.
Eh, I did a little research and stuff about building my own computer. I don't think I'm going to go that way. I'd rather just buy a pre built computer just to ensure I don't mess it up, and that it has a warranty.
Well, you're not going to get a high-end pre-built gaming computer for $700. You'll need to build your own to get a really good one. A pre-built one will be alright. Maybe good. But for a really good one you'll need to build one. I built one when I was around 15-16, I found it quite easy as long as you're careful. I didn't have a clue in hell what I was doing. Follow the manuals and it all woks out relatively easy.
most of the parts should have some kind of warranty.
Ok ice decided I'm going to build mine. What the heck. Ill learn bout computers save money and have something to entertain me. Uh I may sound stupid but what do I need to build one? Would anyone mind suggesting my setup? I want good graphics and fast and I moved my budget to $800. Ill have more input later I'm typing this from my phone. Thanks to any help
Does this 800 bucks include a Operating System, Monitor, Keyboard and mouse and speakers?
