What is the best way to clean computer componants?
Compressed air for just blowing off the dust. Rubbing alcohol with Q-Tips is a good way to get everything off and clean out the hard to reach spots.
Also use a paint brush. I have one that has long soft bristles and that works great. Give everything a quick wipe down and then hit it with compressed air.
Yeah q-tips but, I've had em get stuck on some parts (like the fibers of it)
Long soft bristles... that actually sounds really good and effective.
I use an old toothbrush for fan grills and heatsink fins.
Hmm... strong and sturdy
compressed air is what i use, you can get it at your local target, but you have to have an id to buy :/
