I'm soo lost it's incredible!
Bigwoods
banned
So I bought a MacBook to facilitate my job (DJ)
My songs are on a desktop running 32-bit Vista, I have about a few GB of music. So I bought a 350GB External HD..
NOW, I uploaded all the songs onto the HD (they're all MP3 format) and everything was good, until I plugged it into my MacBook, it aknowledged the HD, I was able to open it and see the folder "Songs" where they should have been, but when I opened it.. It was empty.. What do I do?
AT most I can say is the harddrive is for PC only. I think there are some that can be read by both but, some are for a specific type.
Model Of HardDrive?
Hmm... the site lists it as "PC and Mac compatible"
If it's possible... add some other files onto it. Even a notepad document or something. If that still isn't read. I'd recomend totally erasing the external drive and than plugging it into the mac and see if theres a format option. Then if you can format it... go back into windows and grab like 2-3 files and put them on there and then hook it back up to the mac.
I know my Mac reads MP3 files because I put about 5 on a 2GB stick and the Mac had no problem opening them..
When I plug the extenal HD into my Mac it says im only allowed to read, would that have anything to do with why I cant see my music?
