buying new computer- is this price ok?
revving
Hi I'm new here.
I'm trying to buy new computer, this is for 3d rendering purpose.
I heard it's more cheaper to build own computer rather than buy dell computer, but I never done it, so I asked some computer store that is around my house and they gave me this spec with $1049.
• Intel Core 2 Quad Q9660 2.83G 1333Mhz
• ASUS P5N-D Motherboard
• Cosair Twin2X PC2 8500 DDR2 1066Mhz 4GB Memory
• 1TB - SATA 7200RPM Hard Disk Drive
• nVidia GeForce 9800 GTX 512MB DDR3 PCI-e 2.0 SLi Ready
• Cooler Master Cosmos 690 Black Mid Tower with 500w Power Supply
• Dual Layer DVDRW Drive
• Integrated 7.1 Channel Audio
• Wired Keyboard / Optical Mouse / Standard Speaker (Black)
• Microsoft Windows XP or VISTA Operating System
What do you think? is this good price? Or do you think it's better to try build my own?
and another question.. is Intel Core 2 Quad is better or i7 is better for 3d rendering?
That's not a bad build, pretty good actually, but it's not a $1000.00 build.
You could build an i7 pc for that much.
And yes, the i7 is the best on the market right now, hands down.
Depending on what program you use, more cores are potentially better,
and the Core i7 Hyperthreads, so essentially 4 cores split into 8.
Here's a Core i7 build for $1025.91 before shipping and rebates:
$985.91 after rebates
Core i7 920 ($279.99)
Foxconn FlamingBlade GTI LGA 1366 ($174.99)
OCZ Gold 6GB (3 x 2GB) 240-Pin DDR3 ($99.99)
($89.99 after Rebate)
CORSAIR CMPSU-650TX ($99.99)
($79.99 after Rebate)
XFX Radeon HD 4850 1GB ($117.99)
Western Digital Caviar Black 500GB ($69.99)
LG Black SATA CD/DVD Burner with LightScribe ($27.99)
RAIDMAX Tornado ($44.99)
($34.99 after Rebate)
Windows Vista Home Premium SP1 64-bit ($109.99)
Includes free Windows 7 upgrade coupon
Thank you Bodaggit23 for your information!
uh, if you don't mind, I have more question.. I use maya 2009, and I want to use with nVidia graphic card since I had so many bugs with Radeon card. Do you have any recommendation for nVidia graphic card? and plus, I want to stick with window XP, but I also heard XP only use 3.5GB of RAM...
installing 4 GB ram and i7 CPU with XP, what do you think?
Thank you for feedback Bomberboysk!
I only have 32-bit maya and don't have money for 64 bit and I had some annoying maya bugs with Vista, that's why I want to stick with XP. What about I go with Core Quad? any recommend?
Yup, XP is outdated...
Yup, go with vista 64 bit, and you can have all the ram you want, especially what your gonna use it for, 4 gigs is good, but it would benefit you to go for at least 6gigs.
I see.. Thank you mx344
OK i'm going to buy 3 GB Ram and XP.. can buy any kind of ram in Newegg with motherboard Bodaggit23 recommend?
