Which ATX connectors do i connect the PSU to?
Drastik
I find on this motherboard (Gigabyte GA-MA770-UD3 770 Socket AM2+)
and i see that there is a atx 24 conenctor (20+4 cable) which the psu has so i connected the atx 24, so do i still need to connect the atx_12v connectors? on the board there is two connecter ports side by side (atx_12v_2x4) like this
(http://www.hardwarezone.com/img/data/articles/2004/1192/tutorial-atx12_power_conn.jpg)
do i just connect one of them, or both of them? or none?
i read in the manual that without the atx 12v the comp wont start (cpu power connectors)
There's only one 4 pin plug on the board.
It's for the CPU. Must be plugged in.
The extra plug on the psu will not get used.
You should read the whole thread. I suggested the same, but the OP stated clearly, his board is a REV 2.0, which has an 8 pin connector on the board.
