bomberboysk
Depends who you deal with tbh, im going to refrain from my relative hatred of geek squad though since i may be getting a job there hehe.truth is that the geeksquad are not "geeky". I could probably solve most problems faster/cheaper than they. They once told me I could put a video card that was almost a thick as the laptop itself into my laptop. PLUS i had it open there wasn't room, AND wtf would the heat go? Id kill the laptop. Also, they told my dad, more than once, different stores even, that he would need a $300 router to take one of those laptop connect cards and get the signal to be wireless for all the other computers at the same time, when all you really need is a $20 router and a $10 cable, and some patience. I wouldn't trust the geeksquad for sh*t, sorry for the language.
To the OP, have you checked the case and made sure someone didnt screw up when they built it and forgot a standoff or something? Id take it completely down and check everything, although it could be a motherboard issue. If you are constantly getting corrupted files, it could be a faulty IDE or SATA controller on the motherboard.
		 (Sidebar buttons work better
 (Sidebar buttons work better )
