Best gaming laptop under $2,000?
morgothaod
Hi everyone,
What is the best gaming laptop for $2,000 or under? I know desktops are better for gaming, but I still want a laptop. Thanks.
:good:
its way better than the gateway(btw never buy gateway, theyre crap), and it is the same specs as the alienware, except asus is better and cheaper. with alienware, ur just paying for the brand.
T9600 probably be better than Q9000 in gaming at the moment as most game haven't ulitize quad core.
http://www.newegg.com/Product/Product.aspx?Item=N82E16834220577
alienware got dual GTX 260M, it is the best spec. It will down to you if you really want to spend extra $500 for SLi GTX 260M
According to notebookcheck.net, GTX 260M ~ desktop 9800GT. SLi GTX 260M is 40% faster than single GTX 260M if driver support properly, and perform similar to single GTX 280M
Personally, I'd rather save $500 and go with the Asus.
But really, that Alienware is a good build. Honestly, I'm not a fan of Alienware.
Just my $0.02
which is better (Both are $3,000 systems, I may pay that much since it only comes to a little over $100 a month)?
Alienware
Software & Services
Windows Vista Home Premium (64 bit) + Windows 7 Home Premium Upgrade Coupon
Intel® Core™2 Extreme Quad QX9300 2.53GHz (12MB Cache, 1066MHz FSB)
Dual NVIDIA® GeForce® GTX 280M, 2GB – SLI® Enabled
17-inch WideXGA+ 1440x900 (900p)
4GB Dual Channel DDR3 at 1066MHz
250GB 7,200RPM w/ Free Fall Protection
Slot-Load Dual Layer DVD Burner (DVD+-RW, CD-RW)
1Yr Ltd Hardware Warranty, InHome Service after Remote Diagnosis
Space Black – Anodized Aluminum
or
Sager
- Chassis Color: Silver Trim
- Display: 17" Wide Viewing Angles WUXGA LCD with Super Glossy Surface (1920 x 1200)
- Processor: 45nm Intel® Core™ 2 Extreme Processor QX9300 / 12MB L2 Cache, 2.53GHz, 1066MHz FSB[+$915.00]
- Video & Graphics Card: Nvidia Quadro FX 2700M Graphics with 512MB DDR3 Video Memory[+$165.00]
- Operating System: Genuine MS Windows® VISTA Home Premium 64-Bit Edition
- Memory: 4GB Dual Channel DDR3 SDRAM at 1066MHz - 2 X 2GB[+$55.00]
- Primary Hard Disk Drive: 250GB 7200rpm SATA 300 Hard Drive[+$20.00]
- Optical Drive: 8X DVD±R/RW/4X +DL Super-Multi Drive & Software
- Wireless Network Card: Intel Wi-Fi Link 5300AGN - 802.11A/B/G/N Wireless LAN Module
- Bluetooth: Internal Bluetooth V2.0 + EDR Module
- Intel Robson Technology: Intel 4GB TurboMemory Module[+$85.00]
- Primary Battery: Smart Li-ION Battery Pack
- Integrated Security Device: Fingerprint Reader
- Microsoft Office: Microsoft Office Ready with Free 60-Day Trial
- Warranty: Sager 1 Year Limited Parts and Labor Warranty
Is that high end SLI sager better than the alienware ($3,300) with the following specs?
As for price, I first mentioned $2,000 but I may go up to $3,000 if it makes a huge difference.
Also is an SLI better than a non- SLI?
id go for the sager:good: the sli question is very game dependent.if what your playing supports sli it rox.if the game doesnt support sli its of no benefit.
I'm gonna be playing games like Diablo 3, Quake 4, Soldiers of Fortune 2. Basically first person shooters.
Alienware
Software & Services
or
Sager
Nvidia Quadro FX 2700M is not a gaming card.
