Stoic Sentinel
I'm wondering whether to upgrade my DirectX 9 to 10, I'm really wondering because a lot of people had problems with DX 10 and Battlefield 2, which I plan to keep playing for many years to come
What OS are you running? DX10 is for vista only...
or, you can google "the alky project" to get it on XP, some people say it works and others say it doesn't. Either way, you will need a DX10 graphics card.
It is, XP only supports up to DirectX 9. As far as B/F 2, it runs just fine on Vista or 7Indeed I did not. I've always used Windows XP 64-Bit, so I was hoping Vista would be a step up.
