Stoic Sentinel
I've been recommended by bomberboysk to this motherboard to build a computer: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131402, my question is: will it come with a heatsink and fan, or will I have to buy one?
(Thats what i was saying about the 1283 blocking slots, the smaller one fits fine though in all the cases ive seen)Not going to rant about not liking Xig, but if you do get one you better check it out. On a AMD socket, the way most of the pipes and clips are made on Xig you can only point them up or down.
Heh, i remember when the blacks didnt even have a heatsink. Why do people expect so much from a cpu a few bucks cheaper when everyone who overclocks gets an aftermarket anyhow lol.The stock ones are not that bad, there just the standard AMD heatsink (upsets people because its a BE model). It will be just fine unless you start cranking up the voltage.
You'll learn, plus the stock heatsink can do a little bit of overclocking.I don't think I'll be doing any over-clocking, I'm a nooblolz.
