Sys Fan Error
bpy5000
After moving my pc to a new case, on startup I get a sys fan error. After a few days of unsuccessful troubleshooting it is now getting worse. Now after i hit F1 to continue past the error, I get a blue screen and then it restarts itself. This cycle continues until I manually power it down. Does anyone have any suggestions?
What does the actually Error say?
these system fail errors is due to the actual fans plugged into the motherboard are not working properly. If they are spinning and working then try to disable Fan Fail warning in bios and that should fix it.
Most retail manufactures have bios locked so that fan fail will never go away unless you can disable it.
Also besure you plugged the fans in right spot. Sounds dumb but my parents HP is PICKY on where the fans are plugged into due to sensors on the fan
