Need Help with new Build
So you want me to replace that motherboard with the one above?
Leaving my price around $370
Am i missing anything else for my computer?
Like a power supply or cd drive or anything
Here is what I think you should get that is if this is going to be a gaming computer it not then the only thing you should change is the motherboard.
This is a little more but 6X better then what you posted.
Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131391
CPU and GPU
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.238493
PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817189014
RAM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
HDD
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136098
Now I noticed you didn't pick a OS, Case or CD/DVD drive do you already have these things or is this just an upgrade.
The OS and case i can get, the only thing i dont have is a DVD Drive, unless i take it out of one of the computers i have here.
One problem,
Everything you gave me here works in newegg.CA
except the combo CPU GPU
Would you be able to get me seperate CPU AND GPU in Canada?
and maybe a little cheaper
One problem,
Give me a second and I will see I can do for you I had no idea you was in Canada.
MotherBoard: http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131391
$84.99
PSU: http://www.newegg.ca/Product/Product.aspx?Item=N82E16817154026
$34.99
CPU: http://www.newegg.ca/Product/Product.aspx?Item=N82E16819103688
$69.99
Ram: http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231122
$59.99
HD: http://www.newegg.ca/Product/Product.aspx?Item=N82E16822136098
$59.99
Total: $309.95
Yeah i just edited after seeing your post,
that is the total price WITHOUT the video card
You think youc an find a cheaper one lower than $80 ?
That PSU is carp very low quality and will not power much of anything looks for a brand name PSU like PC Power and Cooling, Corsair, Antec, Thermaltake, Xclio, Cooler master, OCZ, FSP, Seasonic, Silverstone, Zalman.
Its either i get some parts, and then buy a case
Or i can settle for this
Motherboard - Asus M4A78-EM AM3 Native, but supports AM2 / AM2+ (Bought Aug. 09)
Processor - AMD Athlon™ X2 3800+ @2Ghz
Memory - 4x 1Gb DDR2 @ 667Mhz (Bough April 09)
Harddrive - WesternDigital 200gb HDD (WD2000JS)
Video Card - Asus nVidia 9400GT 512mb w/ native HDMI, DVI and VGA (Bought June 09)
Optical Drive - HP DVD Writer 1070r (Bought Jan 09)
Sound: Realtech onboard 8 channel surround sound
Network: 1000mhz onboard and 54mb D-Link Wireless A/B/G card
That's being sold for $400,
You prefer i build one or go with that?
That computer is terrible you can build one 10 times better for $50 less.
Here is the GPU and PSU you should get
GPU
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814127415
PSU
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817153023
Ok ignore my last post above.
This Leaves me with,
MotherBoard: http://www.newegg.ca/Product/Product...82E16813131391
$84.99
PSU: http://www.newegg.ca/Product/Product.aspx?Item=N82E16817153023
$44.99
GPU: http://www.newegg.ca/Product/Product.aspx?Item=N82E16814127415
$70.49
CPU: http://www.newegg.ca/Product/Product...82E16819103688
$69.99
Ram: http://www.newegg.ca/Product/Product...82E16820231122
$59.99
HD: http://www.newegg.ca/Product/Product...82E16822136098
$59.99
Which leaves me at $394.94
Thanks, ill take this into consideration
One more thing, am i missing anything?
Should i get a soundcard, and whats the cheapest dvd/burner i can get with this?
$84.99
$44.99
$70.49
$69.99
$59.99
$59.99
Everything looks good your are going to have one nice computer when you are finished. The only thing you are missing is a Case, OS, and CD/DVD drive.
You said you had a CD/DVD drive in a computer you already have you can use that or if you wont to by a new one I will post a link for you.
Yeah post me a link for a cheap case please, and thank you.
I have one, but it's a little too old i want my computer to look nice, haha.
Also post me a cd/dvd burner just incase i do need one
sorry for the trouble
No trouble I like helping people I could be doing some way worse right now but this is what I like to do.
How much do you have in mind for a case and CD/DVD drive.
Yeah i have this
$84.99
PSU: http://www.newegg.ca/Product/Product...82E16817153023
$44.99
GPU: http://www.newegg.ca/Product/Product...82E16814127415
$70.49
$69.99
$59.99
$59.99
Just want a cd/dvd burner not to expensive?
Also just what cheap case would be good for this build
Yeah i have this
$84.99
$44.99
$70.49
$69.99
$59.99
$59.99
Ok considering this up here, could i get a comparison on these parts from this computer store because it's close to me and no shipping.
Motherboard: http://www.canadacomputers.com/index.php?do=ShowProduct&cmd=pd&pid=023835&cid=MBD.350
$65.99
PSU: http://www.canadacomputers.com/index.php?do=ShowProduct&cmd=pd&pid=020615&cid=PSU.731
$59.99
GPU: http://www.canadacomputers.com/index.php?do=ShowProduct&cmd=pd&pid=019779&cid=VDC.243
$47.99(After $20 rebate)
CPU: http://www.canadacomputers.com/index.php?do=ShowProduct&cmd=pd&pid=025110&cid=CPU.907
$71.99
Ram: http://www.canadacomputers.com/index.php?do=ShowProduct&cmd=pd&pid=023357&cid=RAM.346.307
$72.99
HD: http://www.canadacomputers.com/index.php?do=ShowProduct&cmd=pd&pid=021509&cid=HDD.443.877
$59.99
Total: $378.94
Just want to know which build would be better, also remember that from this Canada store i dont have to pay for shipping so that makes it easier on me, and if anything can be approved to match the other build for less than $420, let me know
