Advice on my new build (first in about 5 years!)
evertonhero
Hi all,
im quite new to all this, ive spent the past week researchin parts etc and heres what I have found that looks good...I think!!!
ASUS Crosshair III AM3 - £140+
Phenom II x4 965 - £180+
Either 6gb xms3 corsair ddr3 ram - £120+
or 4gb corsair dominator xms3 £70+
Sapphire radeon HD either 4850/70/90 - im not to sure how all this crossfire works but im sure 1 card will be enough for me.
Samsung 1TB 3gb/s 7200rpm hard drive - £50-60
ocz modxstream pro 500w - £50+
A Case....no idea yet....
Right so im sure thats all the key main components that ill need to get...
So a total of around £600+ is what its looking at going to be
If im missing anything or someone can recommend a better part for the prices etc please let me know
Will all this work fine? will it last a few years without a major update?
Thanks for any replys!! (FIRST POST WOOHOO!!)
any adivce appreaciated (sp?) im going to the computer fair tomorrow to pick up all the parts!!!
FYI:
AM3 boards only run Dual Channel DDR3 so you
want to chose Dual Channel kits that come in pairs.
For 6Gigs, you would need 2x 2Gig sticks and 2x 1Gig sticks.
If you bought a 3x 2Gig kit, the board would only run in Single
Channel mode, which would severely damper performance.
Slots must be filled evenly. :good:
Thanks alot for the advice,
is this ram much better than the ones i picked?...
http://www.overclockers.co.uk/showproduct.php?prodid=MY-169-OC&groupid=701&catid=8&subcat=1387
I used to be a big gamer but not so much nowadays, im lookin for a good build which is going to last me a few years, but il still av the option to load up like diable 3 wheneva that gets released?!?!?!?
ive head abit about different version of xp etc, im on a 32bit xp now, should i stick with this or move to a vista 64bit? or even 64xp??
im not to sure on the M4A785TD-V MB, will this be more suitable to me? im jus tryin to get which is most future proof?!?
thanks again!
