Need help connecting USB port
vr2jetta
I just switched the motherboard and case for my desktop and cant figure out how to hook up the USB ports for the front of the case. Can anybody give me some help? The board is a gigabyte ga-k8nf-9. Here are some pics.
This is what I am trying to hook up:
These are the wires coming from the back of it:
This is where I believe they plug into on the MOBO.
Ive narrowed it down to 2 of the wire clusters being used for the most common usb ports. Each of them having 5 wires coming from them. They are labeled:
Cluster 1:
Big Black-ground
Small black-ground 1
Red-VCC1
Green-USB1+
White-USB1-
Cluster 2:
Big black-ground
Small black-ground 2
red-VCC2
green-USB2+
white-USB2-
Which ground should I use if following the diagram?
I assume The red wire (VCC) is the power?
Look in you motherboard manual it will tell you what goes where. Also it would help if you told us what kind of motherboard you have.
That is exactly what I found when I searched. Thanks! And the diagram the g25racer gave was the exact one I got! Thanks all!!
One more thing. I followed the directions to plugging my front audio ports too but they are not working. I do have a small set of usb speakers plugged in to the back, do I need to unplug them for the front port to work? The input area on the MOBO for the audio ports had a few jumpers in it too. 2 Jumpers, 5-6 and 9-10. Thanks again all!!
