Disabling 'New Programs Installed' Notification
jhonrox
Hey guys,
I was just wondering if its possible to disable the 'New Programs Installed' notification in the start menu, along with the yellowish highlighting on the program icon itself? Its kind of annoying to see it everytime I use the start menu, in XP as well as Windows 7.
Any ideas anyone?
Thanks! :)
He asked how LMGTFY worked so I did one to him on it.
It was ME who asked how LMGTFY worked, and it was ME who then said "No, don't answer that! I just found out how it works!!"
After that, why would you even bother responding with a useless post?? :confused:
Read the previous posts before you post a reply, will you? And you might want to stop posting on this thread again, seeing that its now solved.
