Post Your Lowest idle Temps
bigrich0086
This is my idle temps is 76oF room temp. For the record my temps are on air not water
Temps recorded using Everest
then whats this?
Processor: AMD Phenom x4 Quad Core 2.3ghz @ 2.51 Idle 20oC/Load 35oC
lools like 20Celsius ?
:P
lets not be a smart a$$. Post screen shots. I could type i idle at 2c. But need screen shot of the actual temps.
This is my old rig, workin i7 now. They aren't my lowest temps, but I thought I would post it because its a pretty darn good temp considering the OC I had it on :D
Here are some temps after I'd been using my computer a bit. Nothing major, mostly surfing the web, chatting, and playing a flash video in Media Player Classic. I'm not overclocked right now seeing as I don't need the extra performance/heat.
note: I know the 12v is all weird... It's fine in the BIOS. I'm quite sure if the 12v was only 1v I'd have some serious problems :P
MY lowest idle temp is 29c, no screen shot at the moment, not on that rig.
Stock cooler.
tinuq tx-2.
Just thought now might be a good time to point this out, alt+PrintScreen just print screens the active window rather than the entire screen. Just figured I'd try and help save some loading times on those with slow internet. :)
What the heck I created a thread like this 2 weeks ago and barely anyone responded. No it gets created and people respond. WTF
Anyways
3.2ghz stock
Full Load muhaa
AMD 4600+ Idling at 29C.
5% Automatic BIOS OC. (If I go anything more than that it becomes unstable... even though temps don't get past 55C
Stock HSF, using Everest.
Although, there's about 2 years of dust in the HS... Which I've been meaning to clean out -.-
But now that I've ordered a new set up, kinda slacking on it.
figure i'll clean it up when switching this system to a htpc.
My lowest was 35 C, sorry I don`t have screenshot because I have deleted the program some days ago and I`m lazy to reinstall it.
