Case Fan's: What to buy?
greasyhippo
Hi,
I have a random medium sized case, not sure what brand, supports 80mm fan's. I would like to know what fan/fans would be good for my desktop. I don't have any fans yet..lol other than the fans that come with the CPU, Graphics & power supply. I would prefer a quiet fan.
Unless your computer is in a sound proof server room, dont get a tornado. Those things are louder than the ultra kaze and will prolly make you go deaf in whatever ear is closest to the pc lol.
The Enermax fans with the Enlobal bearings are really quiet 80mm fans. They have the Magnetic Barometric bearings were the fan basically floats in a magnetic field. I'm using 2 in my case right now.
You can get fans that run at slower speeds and are super quiet if you dont need to move much air seen some on eBay or year noctua's seem good just look at the db they give out..
How much do these cost?
And my idle temperature for my PC (specs in sig below) 45* degrees - 110 Fahrenheit
Also i have a closed case, i don't much care for LED's.. i would pay anything from $0-$50 i guess (although i don't know prices of fans and if they even go as high as $50 AUS). Don't have a budget really i will pay $20 for one easy, just don't want to spend to much. Some very quite or fairly quite fan, my system is loud enough but still an effective one.
Thanks for the suggestions, might i add i am from Australia, so don't recommend American shops/online stores please.
PS: sorry for not replying earlier :good: (I don't have any fans ATM other than the fans that come with the Graphics, CPU and inside the Power Supply)
