Magicalpops
is a dual core 2 GHz processor better than a single core 3 GHz? if so could you tell me how
thanks
thanks
Very nice analogy![]()
Generally yes.
Clock speeds may be faster, but two cores will be faster than one.
Imagine you have 10 gallons of water.
You need to get that water into small containers.
All you have is one hose and a funnel.
Now imagine you had two slightly smaller hoses and funnels.
Two cores will potentially move more data, even though at a slightly
slower rate than a single core.
I understand nowis there a point, like when a single core ???GHz runs better than a dual core ???GHz? or would the more cores you have always make it better no matter what GHz it ran at?
ooo one more question. when you have any processor with more than one like a 3GHz quad core for example. are there 4 processors each running at 3GHz?
I won't be going along with you guys... I am too bad at it.
BUT! If your software doesn't support Dual core, well... bad luck ^_^.
This isn't necessarily true, though, is it? Software doesn't have to be designed to take advantage of two or more cores in order for you to see an improvement in performance. It could simply be, like the two hoses, that each core is running separate processes.
Most probably already know this but I will state it anyway. Processors that are more recent can perform more calculations per clock cycle than older processors.
For example look at an Intel Core 2 Duo E7200 (2.53 gigahertz) Processor versus an Intel Pentium D Processor 960 (3.6 gigahertz) processor. The E7200 is a better processor than the Pentium D 960. It will very likely run almost all software better than a Pentium D 960.
Even if a program is only designed to run off a single-core processor the more modern dual-core would very likely run it more efficiently. This is because a single core of the dual core processor is more efficient at running software than an older single core processor.
