thanks, something is definately funny here,when I do a google the only reference I can find to the numbers 266 on memory also mentions mobile. These jerks I bought from are saying I ordered the wrong ram but the listing says desktop ram.I did a check with PC WIZARD and It recognizes 4 gb but all other programs see only 3 gb.Out of principal I would like to get to the bottom of this,I`m posting the PC Wizard specs in hope that they will tell someone something, any input would be sooo apreciated thanks....
General Information :
DIMM0 : Empty
DIMM1 : Empty
DIMM2 : Empty
DIMM3 : Empty
DIMM0 (BANK0 ) : 2048 MB - DIMM
DIMM2 (BANK2 ) : 2048 MB - DIMM
Information SPD EEPROM (DIMM0) :
Manufacturer : Unspecified
Part Number : 2GBULURTYLBAÿÿÿÿÿÿ
Serial Number : 144C4756
Type : DDR2-SDRAM PC2-6400 (399 MHz) - [DDR2-800]
Format : Regular UDIMM (133.35 x 3)
Size : 2048 MB (2 ranks, 8 banks)
Module Buffered : No
Module Registered : No
Module SLi Ready (EPP) : No
Width : 64-bit
Error Correction Capability : No
Refresh : Reduced (.5x)7.8 µs, Self Refresh
Voltage : SSTL 1.8v
Prefetch Buffer : 4-bit
Supported Frequencies : 333 MHz, 400 MHz
CAS Latency (tCL) : 4 clocks @333 MHz, 5 clocks @400 MHz
RAS to CAS (tRCD) : 5 clocks @333 MHz, 6 clocks @400 MHz
RAS Precharge (tRP) : 5 clocks @333 MHz, 6 clocks @400 MHz
Cycle Time (tRAS) : 15 clocks @333 MHz, 18 clocks @400 MHz
Min TRC : 20 clocks @333 MHz, 24 clocks @400 MHz
Information SPD EEPROM (DIMM2) :
Serial Number : 594C4756
Width : 64-bit
Voltage : SSTL 1.8v
Memory Controller Information :
Memory Controller : DIMM, SDRAM
Number of connectors : 4
Max. Module Size : 0 MB
Supported Speed : Unspecified
Supported Voltages : 3.3v
Error Detection Method : 64-bit ECC
Error Correction Capability : None
Current/Supported Interleave : 1-way/1-way
