Hows this for a computer?
ya.. what us ur budget? tell us your budget and we can work from there, these ones you have posted are low end products. So give us your spending budget and we can help you on what you should get and get your money(s) worth.
Im only 15, Non of my parents are helping me get this so The most i can spend is around like 200$ no more then 250. Try to get it lowest please. Thanks
well why dont u save ur $200 and then get another $200 sameway u got the first $200 then you'll have wayy more options..trust me dude i was in the same situation, and i bought with what i had and couldnt go back. so wait till u get $500 or so, trust me, its worth it!
I don't want to do that because im in a bad bad situation, I don't got a job but looking around for a computer that i can buy for now and im going to sell the computer i have now, in a month or 2 ill have a really good income may be and christmas is there so ill get money. For now im going to sell some stuff i dont have and going to buy a computer, also because i dont have a computer now im using my mom mac thats mainly why. could yo just come up with a list for me so i can see it and get use to the computer soft ware like names and stuff.
THANKS Stanglehold
THANKS Stanglehold
sure let me see what i can come up with, and ill get back to you, if i dont get back to you by tonight throw me a message, and ill have somethign for you, but you going to have to look on multiple site. most likely craigslist...tiger..etc.. ill be in touch
i hope you arent planning on this being a gaming pc, but it will be ok for just surfin the net. and u will also need an OS.
Are you willing to buy off ebay? It will be your best option in my opinion.
I would never buy a computer from eBay.
If you want good components, choose them, or we will help you choose, and build it yourself.
If you can't be bothered to build it yourself, you're best bet is to buy a pre built from a store.
Just my opinion.
