PSI chips
Oh I see so nothing to worry about then. He seems a little slow but I learned alot from his vids.
What CD/DVD burner would you say is the best; he says SATA sucks and to go with IDE what do you think?
ATA (or IDE Connected ;)) DVD Drive is perfectly OK
Sata is best for Hard Drives with their higher speeds
PCI ports are the ports in which you add addon cards like a new Sound Card or Video Card or a PCI Modem etc (in PCs)
No SATA doesnt suck. I still use IDE DVD drives in mine. But only because they have been good drives and havent gave me any problems to replace them. But all my new builds I use all SATA drives. Building a new computer now, get SATA.
Okay I'll probably be getting this then thanks.
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151187
Is this mobo crossfire compatible I can't find any info about it.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128377
"You said thanks to me and then you are deciding on a Sata DVD Drive anyway??" Well he says their ok; I thought thats what you said as well O.o
"Good drive and yes the board is C/F 16X16 slots, a 790FX chipset." Ok thanks
two more questions :P sorry for all this but I want to make sure everything is in good order.
*Which CPU fan is compatible for this card? I couldn't find any blue LED's with AM3 compatibility.
*Will I need to buy a video card?
No, I was saying ATA only, of which is the IDE (connection)
SATA is probably not required.
Anyway either will do I suppose, I just feel that A T A works better with some DVD Writing softwares, but they may have updated all these programs since last I checked
