Sarcastic Gamer
Hey, I need help with Java.
See, I accidently Blocked it with Trend Micro.
And now when ever I try to use a chat room, I get the following message.
Java Plug-in 1.6.0_16
Using JRE version 1.6.0_16-b01 Java HotSpot(TM) Client VM
User home directory = C:\Documents and Settings\Partis
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to <n>
Exception in thread "AWT-EventQueue-2" java.lang.InternalError: couldn't create component peer
at sun.awt.windows.WComponentPeer.checkCreation(Unknown Source)
at sun.awt.windows.WComponentPeer.<init>(Unknown Source)
at sun.awt.windows.WCanvasPeer.<init>(Unknown Source)
at sun.awt.windows.WPanelPeer.<init>(Unknown Source)
at sun.awt.windows.WWindowPeer.<init>(Unknown Source)
at sun.awt.windows.WFramePeer.<init>(Unknown Source)
at sun.awt.windows.WEmbeddedFramePeer.<init>(Unknown Source)
at sun.awt.windows.WToolkit.createEmbeddedFrame(Unknown Source)
at sun.awt.windows.WEmbeddedFrame.addNotify(Unknown Source)
at sun.plugin2.main.client.PluginEmbeddedFrame.addNotify(Unknown Source)
at sun.awt.windows.WEmbeddedFrame.<init>(Unknown Source)
at sun.plugin2.main.client.PluginEmbeddedFrame.<init>(Unknown Source)
at sun.plugin2.main.client.PluginMain$StartAppletRunner.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
load: class com.chatspace.v400320.Chat not found.
java.lang.ClassNotFoundException: com.chatspace.v400320.Chat
at sun.plugin2.applet.Applet2ClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.plugin2.applet.Plugin2ClassLoader.loadCode(Unknown Source)
at sun.plugin2.applet.Plugin2Manager.createApplet(Unknown Source)
at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.net.ConnectException: Connection refused: connect
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(Unknown Source)
at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at sun.net.NetworkClient.doConnect(Unknown Source)
at sun.net.www.http.HttpClient.openServer(Unknown Source)
at sun.net.www.http.HttpClient.<init>(Unknown Source)
at sun.net.www.http.HttpClient.New(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.connect(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at java.net.HttpURLConnection.getResponseCode(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader.getBytes(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader.access$000(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
... 7 more
Exception: java.lang.ClassNotFoundException: com.chatspace.v400320.Chat
I've unninstalled it, and reinstelled it a ton, but it still doesn't work.
Please help.
g: garbage collect
o: trigger logging
q: hide console
t: dump thread list
... 7 more
Please help.
