Vga driver of asus
lulumara
Hi need help in installing the ASUS driver for EAH4350 silent , I did download the driver because I lost my VGA driver then when I install it it doesn't load up instead it says:
Setup cannot proceed because the length of the specified directory path plus the installation folder name exceeds 88 character . Pleas shorten one or both specified limit.And try it again.
Any ideas how should I do that??:confused:
I had Window XP, I did a re-installed the OS 'cause computer doesn't open because of corrupt or missing file such as System 32\hal.dll in window root. I have no alternative I even put the OS software window xp and tried to repair but no luck .
You will need to make sure that you have an item in device manager under system devices labeled "microsoft uaa bus driver for high definition audio" before the hdmi sound driver will install.
I did installed it by clicking the yellow exclaimation point on it and installed under device manager. Thanks again for helping me , I appreciate it so much.
