Judge My Computer Build
+1, best budget case out there, and one of the best budget power supplies imo.
And btw, 1366 coolers do not work for 1156 motherboards, you need a 1156 cpu cooler bracket. Some motherborads have socket 775 heatsink mounting holes however.
Id recommend going Core i5 however, faster clock for clock, overclocks pretty well, and quadcore..
Yep that's what I figured but I haven't see many of the 1156 bracket's around so I wasn't sure.
Core i5 is just an awesome CPU for the price.
Maybe, but it's hideous. :eek:
I think the godspeed looks awesome I'm not a big fan of the front but the rest looks good. What don't you like about it?
So I found these 3 cases and they seem to be pretty good for the price. What do you guys think?
case1: http://www.newegg.com/Product/Product.aspx?Item=N82E16811119203&Tpk=n82e16811119203
case2: http://www.newegg.com/Product/Product.aspx?Item=N82E16811156226&Tpk=n82e16811156226
case3: http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
I have heard a lot of great things about the Antec, but I don't like the fact that it doesn't have a side window. Is there a possibility to put on on?
Usually don't like the side windows, but lately it's grown on me.
All three of those are good but I would probably go with the Cooler Master or the Antec. Which ever one you get your going to have to buy extra fans because most of them only come with one or two. I would go with this case it's one of my favorite.
XCLIO Godspeed Two Advanced
The only thing with that one is that the side is a little bit bulky :(
I think I'll go with the cool master out of those two because it looks a little better and matched the color of my RAM and MoBo.
Hmm so Im still looking at the AMD set up because it's pretty cheap for good gear, but something about getting the i5 and intel set up seems to be a lot better :confused:
The side panel is big because of the 180mm fans.
OK if you get the cooler master then your should get 2 extra 120mm fans one for the side and one for the front.
An i5 is going to be a lot better but the AMD setup is going to play games just as well.
Last question I have, I promise haha :)
In the next two years, will the AMD setup still be pretty good and if I want to upgrade, is the MoBo good enough to upgrade with in the future?
Yep AMD has the best upgrade ability in a year or two you can upgrade to a Phenom II and the new CPU's will probably be backwards compatible. The AMD setup will be good for at least 3 years before you will be struggling to play games and such. When that happens all you will need to do is upgrade you GPU and maybe your CPU and most likely your power supply.
The Antec Three Hundred is a great case.
Haha I play wow and use Photoshop, I dont think it will be running too hot :D and I liked the blue!
Im sticking with the whole AMD set up, but I havnt bought anything because I really can't decide on a case...
No that cooler master is a pretty good case it does lack some fans but that can be taking care of with PCI slot fans and hard drive and RAM coolers.
Fatback, what is the wallpaper on your desktop background? I think it's pretty cool.
Do you mean this one http://wall.alphacoders.com/big.php?p=Sci-Fi-Cyborg-16986.jpg&i=16986 or this one http://wall.alphacoders.com/big.php?p=Artistic-Other-41551.jpg&i=41551&w=1280&h=1024
Just pick what res you want then right click and go to set as background or you can save it.
Check that site out it's probably the best wallpaper site I have found they have everything.
