CPU Bottleneck?
Yup, no problem. I'd have said that from the start but it didn't come out that you had a dell mobo until the second page there.
BTW, I still believe once you get a 2.0 slot that then the CPU will be your bottleneck because of the clock speed. If you can overclock it to atleast 3ghz, then you'll be doing real good. 6gb of ddr2-800 ram is no bottleneck, unless that ram has some high timings. What timings are you running it at?
the timing of my ram is 6 6 6 18 and row refresh cycle time 52 and command rate 2T information get from cpu-z
