Hi. First time here (which I guess is a good thing). My laptop has been shared with my children the last few weeks due to the fact that the kids computer had a power supply failure. All of a sudden I've had some weird things happening. The first thing that was happening was that I was getting random messages when getting on internet stating that the Internet Explorer had experienced a problem and needed to shut down. Then when I would go onto google to search for something other webpages were popping up that I didn't go to. I thought I had fixed with a scan using "Superantispyware" as it found some trojan horses and I removed them:
Trojan.unclassifed/helper-DD
Trojan.agent/gen-small[Mark32]
It cleared up the webpages popping up when I googled and the random closing of internet explorer.
Tonight I got back on and everything seemed real slow. I decided to do another scan with superantispyware and it found"
Trojan.agent/gen-dropper[Lib]
So, i don't know if these are anything very big or not. I also don't know if they were ever truly removed.
The antivirus software that I use is AVG.
I downloaded Malware bytes anti-malware and did a quick scan. Here is the log:
Malwarebytes' Anti-Malware 1.41
Database version: 2818
Windows 5.1.2600 Service Pack 3
9/17/2009 11:37:01 PM
mbam-log-2009-09-17 (23-37-01).txt
Scan type: Quick Scan
Objects scanned: 111644
Time elapsed: 6 minute(s), 4 second(s)
Memory Processes Infected: 0
Memory Modules Infected: 0
Registry Keys Infected: 0
Registry Values Infected: 0
Registry Data Items Infected: 0
Folders Infected: 0
Files Infected: 1
(No malicious items detected)
Folders Infected:
Files Infected:
C:\Program Files\Shared\lib.sig (Adware.Deepdive) -> Quarantined and deleted successfully.
I downloaded HijackThis and did a scan - here is the log file:
Scan saved at 11:58:08 PM, on 9/17/2009
Platform: Windows XP SP3 (WinNT 5.01.2600)
MSIE: Internet Explorer v8.00 (8.00.6001.18702)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
C:\Program Files\HP\QuickPlay\QPService.exe
C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe
C:\Program Files\Hewlett-Packard\HP Quick Launch Buttons\QlbCtrl.exe
C:\Program Files\QuickTime\qttask.exe
C:\PROGRA~1\AVG\AVG8\avgtray.exe
C:\Program Files\Lexmark 6500 Series\lxdfmon.exe
C:\Program Files\Lexmark 6500 Series\lxdfamon.exe
C:\Program Files\Nova Development\Photo Explosion 3.0 SE\calcheck.exe
C:\Program Files\Java\jre6\bin\jusched.exe
C:\Program Files\Windows Media Player\WMPNSCFG.exe
C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe
C:\Program Files\HP\Digital Imaging\bin\hpqimzone.exe
C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe
C:\WINDOWS\eHome\ehRecvr.exe
C:\WINDOWS\eHome\ehSched.exe
C:\Program Files\Java\jre6\bin\jqs.exe
C:\PROGRA~1\AVG\AVG8\avgrsx.exe
C:\Program Files\Common Files\LightScribe\LSSrvc.exe
C:\WINDOWS\system32\lxdfcoms.exe
C:\WINDOWS\system32\nvsvc32.exe
C:\WINDOWS\system32\mqsvc.exe
C:\Program Files\Hewlett-Packard\Shared\hpqwmiex.exe
C:\WINDOWS\system32\mqtgsvc.exe
C:\WINDOWS\system32\dllhost.exe
C:\Program Files\Internet Explorer\iexplore.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Bar = http://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iesearch&locale=EN_US&c=64&bd=pavilion&pf=laptop
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
O2 - BHO: Lexmark Toolbar - {1017A80C-6F09-4548-A84D-EDD6AC9525F0} - C:\Program Files\Lexmark Toolbar\toolband.dll
O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
O2 - BHO: WormRadar.com IESiteBlocker.NavFilter - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - C:\Program Files\AVG\AVG8\avgssie.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre6\bin\jp2ssv.dll
O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
O3 - Toolbar: Lexmark Toolbar - {1017A80C-6F09-4548-A84D-EDD6AC9525F0} - C:\Program Files\Lexmark Toolbar\toolband.dll
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [nwiz] nwiz.exe /installquiet /nodetect
O4 - HKLM\..\Run: [MsmqIntCert] regsvr32 /s mqrt.dll
O4 - HKLM\..\Run: [High Definition Audio Property Page Shortcut] CHDAudPropShortcut.exe
O4 - HKLM\..\Run: [SynTPEnh] C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
O4 - HKLM\..\Run: [QPService] "C:\Program Files\HP\QuickPlay\QPService.exe"
O4 - HKLM\..\Run: [ISUSPM Startup] "C:\Program Files\Common Files\InstallShield\UpdateService\isuspm.exe" -startup
O4 - HKLM\..\Run: [ISUSScheduler] "C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe" -start
O4 - HKLM\..\Run: [QlbCtrl] %ProgramFiles%\Hewlett-Packard\HP Quick Launch Buttons\QlbCtrl.exe /Start
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\qttask.exe" -atboottime
O4 - HKLM\..\Run: [FaxCenterServer] "C:\Program Files\Lexmark Fax Solutions\fm3032.exe" /s
O4 - HKLM\..\Run: [AVG8_TRAY] C:\PROGRA~1\AVG\AVG8\avgtray.exe
O4 - HKLM\..\Run: [lxdfmon.exe] "C:\Program Files\Lexmark 6500 Series\lxdfmon.exe"
O4 - HKLM\..\Run: [lxdfamon] "C:\Program Files\Lexmark 6500 Series\lxdfamon.exe"
O4 - HKLM\..\Run: [Lexmark 6500 Series Fax Server] "C:\Program Files\Lexmark 6500 Series\fm3032.exe" /s
O4 - HKLM\..\Run: [PhotoExplosionCalCheck] C:\Program Files\Nova Development\Photo Explosion 3.0 SE\calcheck.exe
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 9.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre6\bin\jusched.exe"
O4 - HKLM\..\Run: [Malwarebytes Anti-Malware (reboot)] "C:\Program Files\Malwarebytes' Anti-Malware\mbam.exe" /runcleanupscript
O4 - HKCU\..\Run: [updateMgr] "C:\Program Files\Adobe\Acrobat 7.0\Reader\AdobeUpdateManager.exe" AcRdB7_0_9 -reboot 1
O4 - HKCU\..\Run: [WMPNSCFG] C:\Program Files\Windows Media Player\WMPNSCFG.exe
O4 - HKCU\..\Run: [SUPERAntiSpyware] C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe
O4 - S-1-5-18 Startup: Vongo Tray.lnk = C:\Program Files\Vongo\Tray.exe (User 'SYSTEM')
O4 - .DEFAULT Startup: Vongo Tray.lnk = C:\Program Files\Vongo\Tray.exe (User 'Default user')
O4 - .DEFAULT User Startup: Vongo Tray.lnk = C:\Program Files\Vongo\Tray.exe (User 'Default user')
O4 - Global Startup: HP Photosmart Premier Fast Start.lnk = C:\Program Files\HP\Digital Imaging\bin\hpqthb08.exe
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~4\OFFICE11\EXCEL.EXE/3000
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~4\OFFICE11\REFIEBAR.DLL
O14 - IERESET.INF: START_PAGE_URL=http://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iehome&locale=EN_US&c=64&bd=pavilion&pf=laptop
O15 - Trusted Zone: http://www.ebay.com
O15 - Trusted Zone: http://www.zedge.net
O16 - DPF: {0CCA191D-13A6-4E29-B746-314DEE697D83} (Facebook Photo Uploader 5 Control) - http://upload.facebook.com/controls/2008.10.10_v5.5.8/FacebookPhotoUploader5.cab
O16 - DPF: {49232000-16E4-426C-A231-62846947304B} (SysData Class) - https://wimpro.cce.hp.com/ChatEntry/downloads/sysinfo.cab
O16 - DPF: {5D86DDB5-BDF9-441B-9E9E-D4730F4EE499} (BDSCANONLINE Control) - http://download.bitdefender.com/resources/scan8/oscan8.cab
O16 - DPF: {8100D56A-5661-482C-BEE8-AFECE305D968} (Facebook Photo Uploader 5 Control) - http://upload.facebook.com/controls/2009.07.28_v5.5.8.1/FacebookPhotoUploader55.cab
O16 - DPF: {928626A3-6B98-11CF-90B4-00AA00A4011F} (SurroundVideoCtrl Object) - http://www.homesteadhotels.com/minisite/accommodations/surround/MSSurVid.cab
O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - http://fpdownload2.macromedia.com/get/shockwave/cabs/flash/swflash.cab
O17 - HKLM\System\CCS\Services\Tcpip\..\{1BB634D2-9C9B-4358-9D6B-E674FB3E6294}: NameServer = 216.106.39.2,216.106.39.250
O18 - Protocol: linkscanner - {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - C:\Program Files\AVG\AVG8\avgpp.dll
O18 - Filter hijack: text/html - {9b3f2984-f3ca-49e7-a329-183f3b298616} - C:\WINDOWS\mark_32.dll
O20 - Winlogon Notify: !SASWinLogon - C:\Program Files\SUPERAntiSpyware\SASWINLO.dll
O20 - Winlogon Notify: avgrsstarter - C:\WINDOWS\SYSTEM32\avgrsstx.dll
O23 - Service: AddFiltr - Hewlett-Packard Development Company, L.P. - C:\Program Files\Hewlett-Packard\HP Quick Launch Buttons\AddFiltr.exe
O23 - Service: AVG8 WatchDog (avg8wd) - AVG Technologies CZ, s.r.o. - C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe
O23 - Service: hpqwmiex - Hewlett-Packard Development Company, L.P. - C:\Program Files\Hewlett-Packard\Shared\hpqwmiex.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
O23 - Service: Java Quick Starter (JavaQuickStarterService) - Sun Microsystems, Inc. - C:\Program Files\Java\jre6\bin\jqs.exe
O23 - Service: LightScribeService Direct Disc Labeling Service (LightScribeService) - Hewlett-Packard Company - C:\Program Files\Common Files\LightScribe\LSSrvc.exe
O23 - Service: lxdfCATSCustConnectService - Lexmark International, Inc. - C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\\lxdfserv.exe
O23 - Service: lxdf_device - - C:\WINDOWS\system32\lxdfcoms.exe
O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
End of file - 8883 bytes
Any help would be greatly appreciated!
Folders Infected: 0
Files Infected: 1
Folders Infected:
Files Infected:
Boot mode: Normal
Running processes:
