New Rig
Manny123
Hey I was just wondering if everything here looks good and will work properly, and If the power supply will be enough to handle everything accordingly.
COOLER MASTER HAF 932
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
Intel Core i7 920
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
EVGA E758-A1 3-Way SLI
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188039
eVGA GTX 285 FTW Edition 1GB x2
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130483
Thermaltake Toughpower 850w
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153072
CORSAIR DOMINATOR 6GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145224
Western Digital VelociRaptor
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136322
LG Black 8X BD-ROM 16X DVD-ROM 40X CD-ROM SATA
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136162
ASUS Xonar Essence STX
http://www.newegg.com/Product/Product.aspx?Item=N82E16829132010
Cooler Master V8
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103055
Also, I was wondering how much of a difference I would notice between these two RAMs.
VS
CORSAIR DOMINATOR-GT 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 2000 (PC3 16000)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145255
Thanks a lot,
Manny
Dude, that rig looks pretty sick.
The difference in the ram is that the second one is clocked higher, so it will be a little faster.
Hmmm, I think I might change a few thing around. After some review of the GTX 285's I found that they have A LOT of problems, so I might go for the GTX 275's. Also, they just came out with;
Intel Core i7 860 Lynnfield 2.8GHz 8MB L3 Cache
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115214
For like 10 dollars more, that's better correct?
I'm not too sure about the RAM though, I might go for 12GB of the lower priced Dominator.
That run on LGA 1156, not LGA 1366...
