I've been waiting to build a media pc for a while now, wanted to build something thats pretty affordable, to make the story short, i ended up building a website for a guy for some parts, (he builds computers for a living.)
Comment on what you think, or if I should change anything:
Unchangeable (Things being sent):
Antec Earthwatts 750w PSU,
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371026&cm_re=750w-_-17-371-026-_-Product
EVGA 780i Motherboard,
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188024
Western Digital Raptor 150gb,
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136296&Tpk=raptor 150gb
3gb ddr2 ram, not sure what brand
DVD rom/rw drive
Changeable (Things i'm ordering):
1tb HD, not sure which I should buy,
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
Intel Core 2 Duo e8400,
http://www.newegg.com/Product/Produ...5037&cm_re=intel_e8400-_-19-115-037-_-Product
Zalman 9700 Cooler,
http://www.newegg.com/Product/Produ...8020&cm_re=zalman_9700-_-35-118-020-_-Product
Video Card: Open to options:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121291&cm_re=hd_4870-_-14-121-291-_-Product
Or a gtx 260
Antec 300,
http://www.newegg.com/Product/Produ...129042&cm_re=antec_300-_-11-129-042-_-Product
I think thats it other than a few case fans and other accessories. I will not be buying this stuff from newegg most likely other than the hard drive.
DVD rom/rw drive
Zalman 9700 Cooler,
Or a gtx 260
Antec 300,
