Case with a lot of airflow
Skorax
I'm looking for a case that has a lot of airflow and fans. Perferrably a military design(camoflauge perferred, if not all good). Budget is no more than $250 for the case.
when spray painting a case, what do i need to do? I'm gonna try and make it into a military design color
the haf is sweet! Modding mine right now. Big Lots of big fans and quite. Tough looking too. To paint i would first give it a good sand to take off any clear coat and roughen it up to give the paint something to stick too. But make sure u sand it even. Then wipe it down with paint thinner, not lacquer thinner. Dont touch it after u wipe it, it could leave finger print marks after u paint. Yes the oil from your fingers will leave a print. Now just paint. After u fin painting put a shot of clear, light sand and a final clear. done. That should do it, anybody got some tweaks to my suggestions?
i like that HAF 932. good price, lots of airflow. only question is a lot of the reviews said some of the parts in the case felt really cheaply made, have you found that problem also?
