Need CPU Guide
nindisp
Hi,
I am trying to figure out what to buy, a laptop or a Desktop.
Can someone help me sort out a list top 5 cpus or laptops or desktops and some sort of performance comparison?
I am guessing that the i5/i7 core are the best, followed by quad core, then core 2 duo? But there are so many models within each.
Ideally I want a desktop replacement laptop but only if it is future proof and has the latest CPU, otherwise I may just buy a powerful desktop and a decent laptop to go with it.
Any advice is welcome.
Thanks!
Hi,
Laptops are made for mobility, if you feel that you always be in the same place when you are on your computer (ie at your computer desk) then stay with a Desktop
By the way, seeming you have the money to possibly buy both! Please wait 1 Month for Windows 7 to be released before purchasing a laptop or whatever computer
If you buy one right now you will get Vista with a free Upgrade to Windows 7 ("Upgrade" Windows disc ? ooo yuk, I only like full versions ;))
Depends on budget, My list would be - i7 920/ i7 860 > i5 750 > Phenom II x3 720 > Athlon x4 620 > Athlon x2 240/ 245
If you buy a laptop (notebook) as your primary computer know that you are really compromising processing power for portability. I would do as you suggested in your post, buy a powerful desktop and a decent laptop to go with it.
Are you planning to buy the components and assembling the desktop system yourself or are you planning on buying a pre-built?
Going to get it built for me. But i want to understand all the components quite well so I can choose all the right ones as usually they try to cut corners somewhere or another.
Yeah looks like you do end up sacrificing a lot of the power for the portability and still end up paying more.
I think im going to go for a i7 chip on a desktop, and look at getting a laptop later depending on exactly what i am going to do with it.
I would have whoever is building a desktop computer for you build with one of the following brands of motherboards:
Gigabyte
Asus
MSI
