Computer is running errors
askcratey
Ok i have this custom mad computer which is old. Its running windows 98. My problem is that everytime i get into a site, it says syntax error and also says running scripts errors. WHat could be wrong
I don't think its a "Memory" or "Hard Drive" problem
It sounds as though its just a non compatible Windows (ie Java etc) and Internet Explorer version, on some of the sites you go on
You can try updating to Windows 98 unofficial SP2: http://majorgeeks.com/UNOFFICIAL_Windows98_SE_Service_Pack_d4131.html
To see if that helps too ;)
Edit:
Basically some sites are just not compatible with old technology any more, an old XP machine may be a good idea to upgrade to, some are really cheap
If you are using an old version of IE then chances are that is what is causing the errors.
Use IE 6 sp1 and it should clear most of it up.
From Microsoft:
The minimum requirements your computer needs to run Internet Expl
orer 6 SP1 are listed below. Additional system requirements are not required when running Windows XP. Some components may require additional system resources not outlined below.
Minimum Requirements
Computer/Processor
Computer with a 486/66-MHz processor or higher (Pentium processor recommended)
Operating System
Microsoft Windows® 98, Windows 98 Second Edition, Windows Millennium Edition (Windows Me), Windows NT® 4.0 with the high encryption version of Service Pack 6a (SP6a) and higher, Windows 2000, or Windows XP
Memory
For Internet Explorer 6 SP1:
RAM requirements depend on the operating system used
Windows 98:
16 MB of RAM minimum
Full install size: 11.5 MB
Windows 98 Second Edition:
Full install size: 12.4 MB
Or if you want to give it a shot, you can hit the Firefox page and see what they recommend.
hello friend
by my experience i think that you use old window but when you open the site
most of site are new (new programs code)
