Can i use any ddr3 ram with my MSI p55-cd53 mobo?
P55-CD53
Manufacturer MSI
Chipset P55 Express
North Bridge N/A
Socket LGA-1156
Memory speed DDR3-2133 (OC), 2000 (OC)/ 1800 (OC)/ 1600 (OC)/ 1333/1066MHz
Processor Types Core i7, Core i5
Number of CPUs 1
QPI Up to 6.4GT/second
Memory Type DDR3
Memory Channels Double
Maximum Memory 16GB
External Graphics PCI Express x1
IGP N/A
South Bridge ICH10R
Audio 8-channel
IDE 133/100/66
SCSI None
SATA 3.0 GB/s
RAID 0, 1, 0+1, 5, 10
LAN 10/100/1000 4 LAN Ports
Firewire No
USB USB 2.0
BIOS AMIBIOS
Form Factor ATX
According to the specs you should be able to. Course not knowing what DDR3 you have YMMV.
Specs MSI P55-CD53:
If you have not already purchased memory, i would highly recommend this memory:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231279
Or this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231281
Or this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820226074
P55 is really overclocking ddr3 SUPER nicely. The ripjaws 2000mhz can hit some very impressive clocks, while the 1600mhz has great timings.
I wouldnt recommend that corsair for P55 due to it being 1.8V
Something you could try is dropping it down to 1333mhz and seeing if it will run stable at 1.65V when you get it.Damn i just brought it!!!!! i cant purchase stuff from newegg as i live in sweden
The onboard memory controller shouldnt be at 1.65v or more, as it can "burn up" the controller.
Putting it to 1333mhz would be downclocking, not overclocking since its rated for 1600mhz. Your motherboard manual should explain how to set memory clocks.Cant i just put the ram in and push the oc button? lol i have no idea how to overclock manually i will end up burning it up for sure
