CharmPeddler
I'm wanting to uninstall/remove the Windows 7 partition on my dual boot w7+xp. I installed W7 first so it is the C: drive. i'm concerned that if i just format it, i will screw up the boot.ini file. is there anyway to move that file, or copy it or whatnot?
i'm wanting to do this with out screwing up the XP files/system.
THEN i know that i'll need to designate the xp system from E: to C:. Can i use EasyBCD for this? (i use that to set up the original boot choice screen.
this is just a LITTLE beyond my scope of knowledge, so i'm looking for a lil help. cause if i mess up the wife's Sims3 game (on xp) she will skin me alive
